Arizona Rock Crawler
Swap day 1 (yesterday)-
pulled all the interior stuff:
Console
Floor plate
Shifter
Disconnected skim module
Disconnected pcm
Pulled clutch hydraulics
Swap day 2 (this morning)-
Pulled starter
Dropped skid
Pulled tcase
Tested output shaft seal on on the 32 and all good!
Do you think you’ll be done with yours before Blaine is done with mine? I think you will.
Don’t forgot to throw a transmission cooler in that thing. You’ll need it out here in the desert.
Hey, if he’s as slow as I am it might not matter 😆
As long as he understands our rates very clearly, its all good.
75 per hour by ourselves with new parts.
150 per hour if you want to watch us work installing new parts.
200 per hour if you want to help us install new parts.
250 per hour if we have to install stuff you started and didn't finish.
I will. Just not yet. Im putting a temp gauge in now and will monitor the temps but will most likely put a setrab cooler in once it’s warmer out.
How much to make a Rubicon with 5.38s and 42rle vibe free?
Reactions: Tob
With the conversation about some of us working on our own vehicle and others jobbing work out to different shops I would like to recommend anyone in the Phoenix area to Michael at Premier Offroad. He is defiantly a 10 star business.
Edit: out of order but you get the idea. It didn’t work until I got the bread wet. I think my bread was too healthy. But basically stuff the hole with wet bread, put a 1” bolt in and pound away and the pressure pushes the sleeve out
Reactions: pc1p
This project was going way too easy so a snag was definitely due. Looked at the torque converter and 2 of the bolts are broken off in the holes... time to take it to my dads and weld a nut on.
