I've never had good luck with the door limiting straps. I've been through several different brands of the nylon straps and all have broken after a few months. I finally broke down and bought some Armadillo Billet stops.
https://www.quadratec.com/products/13029_300X_PG.htm
They're not exactly cheap for what they are, but I figured they had to be better than what I was using. I installed them about a year ago and at first they were great. They were solid, strong and held the door open at two different detents. If I would have wrote a review then, I would have heartily recommended them.
Sooo... They went on last January and stayed on the full doors till June. I ran tube doors all summer so the Armadillos weren't used for 4 months. They went back on in October with the full doors and have been on for the last 3 months. So 8 months total use in the last year.
Yesterday, I felt the door bind up and when I closed the door, it ripped the mount right off the inside of the tub.
The soft aluminum got wallowed out and caused the shaft to bind. This , in turn caused the stop to rip off the mount bracket on the tub.
Looks like I can repair it with some JB weld, a doubler and some small countersunk hardware.
So in the end. I put these through 8 months of gentle use, and not only did they break, they broke a part off the Jeep as well.
Bottom line..... ZERO STAR rating! I wouldn't recommend these in any way, shape, or form. I think I'm gonna try some Paracord straps and see how they work out.
