What are you trying to do exactly?Still no '06?
Having a hard time finding the oem part number for the transmission cooling lines.
Does anyone have a link for the radiator fitting that's converts it to a barbed fitting?
One of the hard lines going to the radiator is leaking (at the crimp by the radiator). I would like to replace it, or just remove that short section of hard line.What are you trying to do exactly?
Use the adapters posted above. Will work fine.One of the hard lines going to the radiator is leaking (at the crimp by the radiator). I would like to replace it, or just remove that short section of hard line.
I would never attempt to replace the fitting in the lower tank. There is a very high risk that you will not get it to seal back up if you dislodge the heat exchanger ports. Just adapt to what is there.Instead of the Hayden 397 that fits into the oem radiator fitting; can someone confirm (or deny) the Hayden 391 replaces it altogether?
Yea mine sits right in. It came with the rubber for the front touching the grill. The other rubber I had on hand I put on the V. Hasn’t budged
View attachment 93985View attachment 93986View attachment 93987
That looks like a good cooler. What brand and model number is that?
I believe I picked up this one
https://www.amazon.com/dp/B000CIGE96/?tag=wranglerorg-20
No it fit right up in the grill just fine. Just know which line is your return lineThanks! I like the "stacked plate" design over the "tube and fin" design of most of the others out there. I am going to have to get this one.
Any trouble mounting this on your Jeep? Did you have to do any drilling or make modifications?
Here’s some info on installing a B&M stacked plate cooler In the grille.
https://wranglertjforum.com/threads...4-supercooler-in-your-jeep-wrangler-tj.15329/
Thanks, Chief!
What is the difference between your B&M 70264 compared to Thunderhead's B&M 70255?
Just the size and BTU rating. The 70264 is 1-1/2 inches thick with a 14,400 BTU rating and the 70255 is 3/4 inch thick with 9,800 BTU rating. The height and width is the same.
I'm having a similar issue. Rubber hose is leaking at the barb on the Radiator. I have trimmed the hose back a little and now its leaking worse. The hose seems bigger than the barb. I might just replace entire rubber hose. Is this what is recommended? Just Don't want to do the wrong thing.
