Do you have to pull the axle shafts on a dana 44 rear end to replace the drum brake backing plate?
If so, is it recommended to change the bearings/seal (if original)? I would prefer to not have to do that if possible.
Does that only need to be done if there is a seal leak / bearing issue?
Thanks
Thanks
