Bad fuel float?
CybrSlydr
TJ Traitor
Lifetime Supporting Member
Casper, WY
The gas tank is 19 gallons, correct?
Fuel gauge read a bit above 1/4 tank so I went to fill up. 10 gallons later, the cutoff engaged.
If this is the case, then the fuel gauge is reading 1/4 full when it's more than 1/2 full.
Thoughts?...
Ive been shunned about a comment I made about this but from what I galther, the fuel gauge on E in the red is about 15 gallons. You can take it all the way down and put 18-19 gallons back in. I’ve only ever fit 16.5 gallons in. Rather play it safe myself
Reactions: CybrSlydr
