Three days ago alternator voltage output was same as V between + and - terminals on battery. With car off, I have the same voltage from negative terminal to alternator post. It's an original alternator, so I change it, start it back up.....and no change. Still not putting out voltage above battery voltage. Voltage does not change with engine load.
So I check PCM to alternator pin continuity. I have continuity from field to PCM and source to PCM. While there I also verify I have continuity from both PCM grounds to the passenger side engine block grounds.
I've been reading a lot of threads on this, I think I have a bad PCM by virtue of a bad voltage regulator? I want to make sure I very clearly understand it, but I think if I jumper 12V onto my generator field pin and it starts charging then that's confirmation of a bad PCM. Or do I jumper onto source? Does that make sense, am I getting that right?
Any help is appreciated. Thanks.
