Basic steelies: Mammoth vs. Pro Comp
WillyWatermelon
Clinton, TN
Looking to buy some basic steel wheels for off-road use. Any word on mammoth vs pro comp? Any other brands I should be considering? Preference would be given to something made in USA. Thanks.
Also, for mounting 33x12.5x15 tires, should I go for 8in or 10in width?
Too many bent steel wheels for me to recommend them.
X2, and stay with a 15x8. I went from aluminum to ProComp steel wheels for a year or two and gave up on steel. I wheel on rocks and the steel wheels were always getting bent and dented enough that they would lose air on the trail. Too much time spent with a BFH trying to keep them so they'd hold air. I went back to aluminum 19 years ago and never looked back. This is a friend's steel wheel after a weekend on the rocks. He went back to aluminum too.
Steel wheels hold up fine if you don't air down too much. I bought steel wheels for my trailer, but plan on using enough psi to protect the wheels. One of the things I don't like about steel wheels is the placement of the valve stem, so relocated the valve stems away from the lip to keep them safe.
I stick with aluminum…. But check out craiger if you want to go the steel route
