Question for the sages:
Does removing the blower motor and checking its ohms via multi-meter give any indication to the motor's serviceability? If so, is there some numerical value that would indicate this item is bad, time to replace?
Background:
My HVAC control plate is becoming warm to the touch. I understand this may be a failing blower motor, maybe its resistor, maybe the controls and wiring, or some combination of any/all three. Otherwise, everything still currently works. I have no outward signs of failure; the fan works on all speeds, the doors actuate, the cold/hot switch makes air colder/hotter. The only symptom is a too warm HVAC face plate.
I'd like to start on the end of this chain (the fan) and work my way back (the controls) to see what may need to be replaced. I removed the fan and its spins via hand. Not surprised, it still works when installed. (However, this is such a subjective metric. I mean yes, it spins once released but not like multiple, full revolutions. Maybe that's enough to tell, I don't know. To me it's subjective.)
I tried checking the fan's circuit and ohms via its pins and I get a completed circuit and about 0.8-0.9 ohms. I've not found anything definitive saying those results are good or bad. Any thoughts or guidance here? I'm somewhat new to testing ohms, so maybe I'm missing something.
My next step will be a removal, visual inspection, and multi-meter test of the resistor. Same thing though, is there any series of numbers I would see that would say, this is bad, time to replace?
Thanks all!
Background:
Thanks all!
