Well, you're not going to get a quality lift for that price, and that certainly isn't enough money to run 35s the way you want to.
To run 35s effectively with quality parts, you're going to need to spend around 10k or more.
You'll need a big brake kit (this is very important if you value your safety), a Currie 4" short arm, SYE and CV driveshaft, proper gearing, alloy axle shafts, lockers (ideally), shocks, and a number of other little things. Either way, when you add all that stuff up plus tires, you're easily looking at 10k or more for quality parts.
Running 35s isn't cheap, that's for sure.
$1500 to $1700 won't get you more than a shit quality Rough Country lift, some shocks, and maybe a few other parts. But if you want to wheel it and not worry, you're going to want the higher end parts, trust me.
As was stated, to go to 35" tires on a TJ/LJ, safely and reliably, you need upgrades for:
- Brakes
- Suspension
- Gears
- Driveshafts
- Skids
- Steering
- BL & MML
- and more
Cutting corners will lead to disappointment, poor performance and/or safety issues. It's not a cheap journey and shouldn't be treated as one
