I’m thinking about installing a sub and amp into my TJ, I have a question on the best spot to route this wire for it to turn on, on ignition. I’m new to the audio world and was wondering and open to suggestions ?
ok thank youAny decent quality head unit will provide a wire to trigger the amp to turn on.
i’m thinking about purchasing a 10inch JL sub the 10w102 and pairing it with a jL audio 250/1. my head unit is the MEX-100bt, and thanks for all the helpDallas. If you were up this way I'd help you. There's plenty of youtube and forum help on here if you get stuck and need help.
What head unit are you using?
What size amp and what sub are you running?
You are running your main power wire directly to the battery with a fuse near the battery? Ground wire as short as possible to a good bare metal ground location?
thank you, i took out my head unit and found it, jus making sure so i don’t have to run it off a ignition source from my fuse boxUsually the Blue or Blue & White wire from the AMP
