Best Steering Stabilizer/Track Bar
thrasherbb
Ohio
What’s the best steering stabilizer for my 05’ TJ with a zone 4 inch lift? Or would a new track be a more superior upgrade? Any thoughts or opinion would be greatly appreciated
I don’t believe they’re mutually exclusive are they?
I put on a Rancho this one below.
Rancho RS5000 RS5407 Steering Damper https://www.amazon.com/dp/B000CB42O2/?tag=wranglerorg-20
Track bar, the Currie adjustable is what I put on as it has Johnny joints and a lot of people suggested it has the best bend for clearance you can find.
Not saying they are, just looking for advice, thanks for recommendation.
a ~$3000 PSC hydro assist setup
What? You did say "best". 🤑
Quite a few here will suggest the bargain bin parts store Monroe SC2928. Others will go Rancho. Some will choose Fox. It all depends on your budget and what you expect.
Yes depending on brand. I'm partial to Rockjock 4x4 (formerly Currie).
Reactions: thrasherbb
Both the less costly Monroe and slightly more expensive Rancho RS5000 are fine. A replacement adjustable track bar is normally only needed after installing a suspension lift which shifts the rear axle toward the passenger side and front toward the driver's side..
