Could you install the Holley LED bulbs in the Koito housings ?
Would that be an economical work around ?
The Holley housings are probably designed for LED use.
No.Could you install the Holley LED bulbs in the Koito housings ?
i did the toyota upgrade and have been very happy with them. one can get brighter h4 bulbs but so far i haven’t seen the need once headlights were adjusted.
No.
The Koito use a standard H4 halogen bulb. Just a couple of bucks on Q-Tec.
The Holley Retro's use a Holley proprietary LED cartridge in a Morimoto housing
The Koito kit is absolute bargain. The glass lens have a great reflector setup with a clean pattern. I ran them with the upgraded harness and 80/100 bulbs. Performance was superb. Bulbs are really inexpensive.. I think I bough a handful of the from Q-Tex for under $5 each.
I just didn't like the 3000k. I also dislike the look of most LEDs kits that are not visually period correct. KC makes another good option. Don't know much about them.
I ordered the Toyota kit yesterday. I’m anxious to get them and get them setup so hopefully I can see better.
I'm running the K Suspension harness already, so I'm thinking of using one of the Toyota harnesses to wire up my new (to me) OEM fog lights.
I'm in the process of making a harness for fog lights from a harness similar to the K Suspension one. I don't want to cut and splice into the OEM fog lights wiring so I'll be cutting the connectors off of the K Suspension relay harness clone and soldering on connectors that I cut off off a pair of TJ fog light extensions. That way the OEM fog light harness stays unmolested.
TJ fog light extension:
I ordered 2 sets last week when the sale was still on, $34 shipped to my local Toyota dealer for 2 sets of H4s plus quality harnesses can't be beat! I called today to get an ETA, and the guy said 3-4 week backorder (thanks, all you other Jeepers). I'm running the K Suspension harness already, so I'm thinking of using one of the Toyota harnesses to wire up my new (to me) OEM fog lights.
They are really hard to beat if you don't mind the warm color temperature.
i love my holley retrobrites
Might work for you. In general, the reflector designed for H4's is less than ideal if you're retro-fitting aftermarket LEDs. Give it try.I’m going to run them for a bit and see. I’ve got the Hella 100/80 H4 bulbs coming from Amazon as well. And, there’s at least one thread about LEDs in these housings, so lots of options!
