Bolt length for winch plate/tow hook
The Real Lxxtsy
IL
I'm in the process of installing my winch and it looks like I need to get new bolts. I'm thinking 3" length in bolts for up front and 2.5" for the two bolts for the sway bar. Grade 8 bolts obviously.
What do you guys think.
Thanks
You probably want about an inch to an inch and a half or so of thread to go into the frame. A bit more won’t hurt, though you’ll have to check the thread length on the bolt. Take whatever the thickness stackup of the bumper, winch plate, and any other accessories (bull bar, hoop, tow hooks, etc) is, add an inch, round up to the next size (if there is enough threaded length) and order that.
Consider ordering Grade 8 flange bolts if you can find them. Flange bolts do a better job of distributing the load on the attachment. McMaster-Carr sells Grade 8 flange bolts
Reactions: The Real Lxxtsy
