Greetings from Moorpark ,
I’m a wee bit anal about everything on my Jeep being in good working order and in some cases looking good, so I replaced the brake fluid reservoir with a new one. Looks great. Part of the project was to bleed the brakes to flush out the old fluid - easy peezy right?
Here’s the problem. I’ll give the answer below.
Loosened right rear bleeder and attached the Mityvac hose and pumped away. No fluid, zip, zilch, nada. Removed bleeder, no fluid. Yes, the reservoir cap was loose and there was plenty of fluid. My first thought WTF over? Then it dawned on me....
When parking The jeep in the garage I set the parking brake. When the parking brake is set it is a mechanical function expanding the brake shoes using a lever and has almost nothing to do with the hydraulics of the brake system. It does however do a great job of relieving all the pressure in the wheel cylinder. Enough so that with the rear of the vehicle jacked up no fluid escaped when I removed the bleeder. Out of respect for those who know better I gave myself a bop on the forehead and uttered a Homer Simpson doh!
