@Jerry Bransford you were spot on with your diagnosis. They had installed the calipers switched and the bleeder valve was below the brake line. I showed your picture and the tech went "yep, I got it wrong". They are bleeding the lines now after switching the calipers.
@Chris can we get Jerry's photo added to the how-to section (if it's already not there somewhere)?
That's great news, glad you got the problem taken care of.
Glad it was an easy fix.
Ps you are best served using the advice on this forum to work on you junk yourself. Nothing worse than putting you life in others hands. I learned this while I owned a 74 Norton Commando. Jeeping is awesome you will love it
for the garage mechanic that is what harbour freight is forToo bad the cost of getting all the dang tools you need is so steep... That's a barrier in and of its-self.
That’s a serious rookie mistake. Anyone charging money for brake jobs should know better. I would seriously look for a new shop/mechanic. If they’re letting someone that inexperienced do brake jobs I’d be afraid of what else goes out the door. If they test drove it after the job as should always be done they would have immediately noticed. If they drove it and still gave it to you that’s even worse. I would probably even have had another shop fix the problem and have the original shop reimburse you for the fix.
