Hi everyone,
I bought a used ZJ axle set and I'm going to use the front axle and take apart the rear to take the existing truetrac out and then get a differential shop to do my rear gears.
I got the differential open and the truetrac opened and I, eventually, got the axle spacer out even though it was extremely tight (I threaded a large zip tie around it so I could pull it).
But now I am having an issue taking out the c-clips. There is not a lot of room and you have to push in the axles quite far to expose the clips enough. It seems like there is enough room to get them off when I work the axle in, they rotate freely and I can get something in between the outer edge of the truetrac and the c-clip but they won't fall out, they won't pull off with magnets (at least what I had at hand) and I've even tried dental picks to grab the two ends or the C from behind and pull them out but that is not working either (got that idea from another forum).
They do pop slightly but then seem to bind. Spent hours on it today with zero progress.
Any thoughts or suggestions?
