Axle joint from Dana 44Is that a Dana 35 or an 8.8?
It’s pushed too far to hit with anything I know of, this has got to have happened before!Get better chisels
Try the other sideIt’s pushed too far to hit with anything I know of, this has got to have happened before!
Huh , the other side is already hit as far as it will go, which is why the other side is lacking space.Try the other side
No that’s the small side shown, literally maybe 1/8” but no angle available.If the side shown is the side with the largest gap, I still see room for a screwdriver blade to get in there.
Meaning that other side has a larger gap? Get a screwdriver or chisel in there and start moving the clip around until you can work it out.No that’s the small side shown, literally maybe 1/8” but no angle available.
I tried every screwdriver and chisel and metal punch, nothing fits!Meaning that other side has a larger gap? Get a screwdriver or chisel in there and start moving the clip around until you can work out out.
Post a pic of the other sideI tried every screwdriver and chisel and metal punch, nothing fits!
And does the clip move at all? In any way? If not, use heat.Yes!
The other side is already pushed as far as it I’ll go and I tried to get underneath , but not happening.Meaning that other side has a larger gap? Get a screwdriver or chisel in there and start moving the clip around until you can work it out.
Simply not accessible, I tried all day!Yes, it's happened before, and it's been solved by using a screwdriver or chisel. Just keep going at it, theres no "trick"
You have all kinds of room. Stick a screwdriver in at 90° to the clip and twist.Simply not accessible, I tried all day!
It’s probably the original from 55k ago.
