Also a good pointI think it’s the angle the lift puts the double cardans at.
There has been mention of people curing driveshaft vibrations with a new set of gears. I wonder if its propagating from there? Or
Unless the engine rpms at a given mph increase over stock I'm just not seeing the argument that regearing is making a driveshaft overspeed condition.if driveshaft speed was so crucial then stock 32rh jeeps would have them more when going fast down the freeway.
Driveshaft speed is tied to engine rpms and transmission gearing at any given speed. Regearing is just a way to compensate for larger tires.
Yes regearing spins the driveshaft faster. But it would need to be faster than stock speeds for that argument to work
I regeared significantly lower than stock, seems like quite a few others do too. But yes, otherwise I do agree. If regear keeps you in the stock rpm ballpark, then all things being equal, you’d have vibes all stock. I think it’s the other factors, lift, brand and build quality of shaft, harmonics, etc combined with such and such driveshaft speed that all add up to make the difference.
The 42rle guys who supposedly have most of these issues aren't spinning much more than a couple hundred rpms more than stock right? I think you're right though.its a combination of factors
Has anyone tried ditching the front double cardan, doing single on both ends of the front shaft, then just adjust the pinion angle to match the t case output angle? My stock rear shaft is smooth as glass at all speeds. Vibes only come on when i install the front.
Sorry, i posted before fully understanding yours , and i can't find how to delete it, so disregard.
first:Sorry, i posted before fully understanding yours , and i can't find how to delete it, so disregard.
Without reading the entire thread (I spent many hours on the "old" ones) I'll give you my experience.
35s/TT/1"MML/4.5" RE/aftermarket driveshafts.
TJUR 06, 4.0/6spd
Geared from 4.10 to 5.13
Got the oscillation. Took it to the driveline shop who did the gears, he spun front shaft to 3700rpm, balanced it and now very smooth - dramatic improvement.
For shits 'n giggles I subsequently pulled the front driveshaft, test drove, and felt/heard no difference.
The lottery ticket I ran and bought didn't work out as well, but it was a great day just the same.
Maybe I need to call around and see if anyone in my area has a machine that will balance up to 3700. From my understanding, the driveshaft balancing equipment industry is heavily dominated by a particular company whose machines top out at 3300, but there could be some smaller players out there that go beyond.
How to say your an engineer without saying your an engineer.
Definitely a small player here. His word was 3700rpm. Regardless, it worked. Good luck.
My 2 local shops maximum was either 3000, or 3300. And a little over a c note to check balance, plus 3 days out.
