Wanted to start a discussion about transmission coolers, specifically the Setrab that @mrblaine uses. I know the a lot of guys will just copy him and run what he runs, because of his experience and knowledge. However, He builds jeeps to run in the desert and climb mountains. I'm planning out an auto swap (42RLE) and looking into coolers. I think I'm going to stick with the Setrab proline series, because of the fit, but I'm contemplating going with a smaller core. The average highs in Michigan for the summer run around 80 degrees and we're pretty flat. We have some hills, but the whole state only has about 1500 feet of elevation change from low to high point.
I do get into mud and sand, so for some brief periods there will be some high slip usage...but will I regret not buying "extra" cooling capacity, or if I get the big cooler, will I be overcooling the transmission and it will never come up to operating temp (if there is such a thing)?
