My 2001 Wrangler does not have the harness for the hard top, but I would like to make the rear wiper work. Can I wire it up with a switch?
I have a 05 tj and wanting to know if amcomplete wiring harness off a 98:tj will work on wiring my hardtop?trying to figure ifmthis complete harness will work ..I have the hardtop,with vented sides,,View attachment 123046this ismthe complete harness off a 98 tj..I have someone thtas selling it to me just making sure it will,work
I am no expert on this but I have studied the diagrams quite a bit with the same question. I'd say if you want that older style harness to work you would need to pull the harness apart. All the wires are there, a few will be different colors but not many. You will mainly be good but will need to splice a few wires here and there. You will also need a different 40 Amp fuse and I can't seem to get the washer tank to line up more than 1 bolt so that too will be a challenge. I started down this road but then found a new old stock hardtop kit so I am working on adding that on instead of finishing a harness disassembly to do what you are asking. The weird thing is the NOS kit I found is for a 98-02 TJ and mine is an 04...so I have some differences to do here as well. Fewer than full harness though. Also, the 100 way connectors changed in 03-06 models and went with something totally different...but its still similar enough that it can be done just more of a head-scratcher figuring out where everything now goes. If I get this done I will put something up on how it went.
[/QUOTE
Scout paper I ended up not getting the harness..yes the 100 pin connectors did change to 60 I believe in like 03 and up.plus the guy never could figure out the wires I needed so I said heck with it..so now all I want to do is run only the defroster..I have purchased the toggle switches I need ,just need to figure out how to wire up defroster,,and if I need a timed relay?I am no expert on this but I have studied the diagrams quite a bit with the same question. I'd say if you want that older style harness to work you would need to pull the harness apart. All the wires are there, a few will be different colors but not many. You will mainly be good but will need to splice a few wires here and there. You will also need a different 40 Amp fuse and I can't seem to get the washer tank to line up more than 1 bolt so that too will be a challenge. I started down this road but then found a new old stock hardtop kit so I am working on adding that on instead of finishing a harness disassembly to do what you are asking. The weird thing is the NOS kit I found is for a 98-02 TJ and mine is an 04...so I have some differences to do here as well. Fewer than full harness though. Also, the 100 way connectors changed in 03-06 models and went with something totally different...but its still similar enough that it can be done just more of a head-scratcher figuring out where everything now goes. If I get this done I will put something up on how it went.
You would need a relay... It goes in the PDC I believe slot 15 its marked HBL. That's the Heated Back Light.
Where do I order a plug set from for a 98 , this would be easier. Use factory rocker switch on dash bezel maybeLast summer I wired the rear wiper on my 1998 TJ SE.
1. I added an auxiliary fuse box, tapping into a vacant slot in factory box that was live only when key turned on. This then served for rear wiper, fog lights and I have one circuit left.
2. Ordered a plug set matching the plug on the hard top and figured out which wires wiper used. Did this by testing with a battery. The wiper motor on my hard top had off, constant, no intermittent.
3. Bought a turn style wiper switch and mounted left of steering column below light switch, it was handy for me.
4. Got some bulk extension cord type wire and routed it neatly to rear, connected to plug, attached a ground in the back.
Works good. Seemed WAY easier than the whole wiring harness, body and dash, option.
My tj 2004 soft top. Bought 1998 hard top had the harness and wiper motor with it just the rear harness. Hot wire from battery to plug on wiper to determine what wire turned it on ,also ground wire from battery to wiper motor wanted to make sure i had a good ground. One wire will be power, could be 2 speed motor . By the drivers seat had to cut the 98 plug off couldn use with 2004 . Make notes of colors ofwires at motor. Ran hot wire from battery again to wires I cut by the drivers seat to make sure they were working. Hot wire from fuse panel with inline fuse To relay to factory rocker switch. Did have to buy washer with pump in it holes did line up . From the pump to the rocker switch . Rocker switch two position wash and wiper on. Did not figure out how to light rocker switch , maybe this spring . You will have extra wires u will not be using could be for heated rear window which I don’t have (yet). Draw a picture of wiring follow it especially if you stop and come back in a couple of days you will forget we’re the heck you were. Good luck not hard relay was a little confusing. You tube wiring relays .My 2001 Wrangler does not have the harness for the hard top, but I would like to make the rear wiper work. Can I wire it up with a switch?
