I bought my 97 TJ with a homemade metal coil spacer lift (around 1.25" I think) attached to it.
I'm not 100% sure it was welded to it, but it wasn't coming off easily - so it's stayed attached ever since.
I've since installed an Ole Man Emu HD spring lift (approx 2.5"-3") and a 1.25" JKS body lift.
(There was also an unintentional raise in the rear when the Ford 8.8 Artec Trussed rear axle was installed.)
(also SYE-CV and 35" tires in summer, with a front HP Dana 30 - doesn't necessarily affect the ride, but required to run larger tires safely)
With Fox shocks, upper/lower adjustable control arms and adjustable front/back trackbars, the ride has never been better.
(When I had Rancho 5000-something (the crappy ones) shocks and only upper adjustable control arms - it rode very rough).
Then again, aside from being in other people's Jeeps, I've never driven my Jeep without a coil spacer installed...but I'm quite happy with my setup as it is now.
