Can you use clock spring for non-cruise control on a cruise control model on 2001 TJ?
Hey there! How did you make out with this? I'm in the same boat - I have a 2002 Sahara with cruise control. It has proven incredibly hard to find the correct clock spring for an '02 with cruise control. As you mentioned above, none of the usual "go to" Jeep sites have anything.
I ultimately came to the conclusion that my clock spring was not in fact bad (at this point) but rather had individual issues. My horn button was broken/stuck - I bought a replacement horn/air bag assembly and that fixed that issue. The air bag light was on in my dash due to the burned out bulb in the air bag on/off switch - I did the trick of getting a replacement bulb and soldiering it in. I did notice that I already had an aftermarket clock spring in the Jeep. So I’m still using it. Since I could find a new unit, I also ordered a used one (not the preferred method) from a specialty Jeep wrecking yard that was supposed to be tested, etc. I haven’t installed to see if it works though as I’m OK for now. One of the other ideas I was going to pursue was getting a clock spring out of similar year Cherokee from a pull a part yard. I actually found one when getting some parts the other day but didn’t buy it. I think they are $25 or something like that there. However, my understanding is that you would have to make the inside diameter of the center hole a little bigger for it to fit the TJ steering shaft.
If you have access to a wrecking yard, I would probably try the Cherokee part approach first. If not, you could also consider getting the available new aftermarket model for TJs with cruise that I mentioned previously (with center diameter too small) and enlarging the center hole with dremel/file. Obviously the wrecking yard piece is a lower risk in case you mess it up due to lower cost - but of course it’s a used electrical part.
At this point our rigs are nothing but collections of used electrical parts, no reason to slow down now.
I’m sure the Mopar parts are discontinued. I verified that through two dealers abs countless Mopar parts websites. From that research as well as the info provided by the used part’s dealer I got a take off clock spring from, there is a difference between the 01-02’s and the years before and after. The ad specifically referenced a hole size difference.
Awesome. Not really lol - But thanks for the response! Really appreciate the insight
