So I got the P0420 code 2 days ago. Right now I'm sitting on the side of the road waiting for a tow. It bogged down so bad it wouldn't go 5mph in 1st. So here is sit half way home grateful in the knowledge that the tow is free.
Yep, plugged cats will do that for sure. Happened to me, though not as bad as this.
Don’t feel too bad, I put a new fuel pump in mine too. Also did a rear main seal because it was leaking worse than I had thought.Yeah. Since purchased I put a fuel pump on and now this. Hopefully I can get a new cat ordered and here before the weekend and no rain I should be good to go come Monday.
How hard was it to get the your original cats off the manifolds? THe bolts on mine look like they are pretty corroded on.
Did you hit with impact?I removed the driver side fender and inner fender. It made things A LOT easier. They were on there bad since they had rust and corrosion, but it wasn't terrible since I soaked them in Kroil the night before.
Not sure what the law is where you are but they cut my cat out, just the rear one was plugged, cleaned it out and welded it back in, a slight difference in the exhaust note but "fixed" in an hour.Yeah. Since purchased I put a fuel pump on and now this. Hopefully I can get a new cat ordered and here before the weekend and no rain I should be good to go come Monday.
I like Wurth Rost Off Max Ice. Comes out of the can ice cold!So-- you like the kroil do you?? Do you think its better than PB Blaster??. People where I use to work, all they ever wanted to use was Kano Kroil-- me, i never really thought that it did much. I kind of always had a bias against it when the can says on it " creeps into openings as small as one millionth of an inch"
When I read shat like that-- I loose all faith in it
My apologies for going off & hi-jacking the thread
Where do you get it from?I like Wurth Rost Off Max Ice. Comes out of the can ice cold!
We have it at the Land Rover dealership I work at.Where do you get it from?
Did mine in the driveway with long extensions, swivels and a breaker bar.How hard was it to get the your original cats off the manifolds? THe bolts on mine look like they are pretty corroded on.
How do they fit?— pretty good ? Were they an exact bolt up replacement with no modifications??Did mine in the driveway with long extensions, swivels and a breaker bar.
Used a flow master replacement cat back from Summit Racing (fast shipping).
Took less than an hour.
Fit up fine no problems. I did sawzall the old pipe out, the flow master was two piece so easy install. I’m happy with it.How do they fit?— pretty good ? Were the an exact bolt up replacement with no modifications??
