Check out summit racing and get yourself a 15mm swivel socket. I was able to grab borla stainless cats for $250.
So-- you like the kroil do you?? Do you think its better than PB Blaster??. People where I use to work, all they ever wanted to use was Kano Kroil-- me, i never really thought that it did much. I kind of always had a bias against it when the can says on it " creeps into openings as small as one millionth of an inch"
When I read shat like that-- I loose all faith in it
My apologies for going off & hi-jacking the thread
I used the Flowmaster as well , I did washers the bolt holes are a little bigger than on the stock flanges. Other than than that the fit was good.How do they fit?— pretty good ? Were they an exact bolt up replacement with no modifications??
Did mine in the driveway with long extensions, swivels and a breaker bar.
Used a flow master replacement cat back from Summit Racing (fast shipping).
Took less than an hour.
I used the Flow master set up as well. I got the Walker quiet muffler and a dynomax tailpipe. I'm at the mercy of shippers so had to mix it up. I wanted stock note and volume. The system worked great. In fact, it solved the CEL plague.Did mine in the driveway with long extensions, swivels and a breaker bar.
Nature's lock tightBTW, no rust here. I can loosen exhaust bolts easily. I'm in heaven now. Grew up in the rust belt of Vermont, everything seizes and corrodes. That was hell.
I’m in the middle of the job now, replacing the whole thing. O2s and all. The bolts to the muffler are a bitch so I’m taking a hacksaw to it today. Easy job but frustrating for sure with limited space.
I was tempted to do the sensors also but didn't want to drop the $$ right now. Probably my kick myself if I have to do it in the future...
Sensors are easy, seriously. Compared to squeezing your hands in with a wrench to get to the bolts, they swap out quick.
Except for those damn clips...
