Hi everyone,
I just performed a temperature test on my TJ with a infrared thermometer reader after driving my Jeep for a good hour around and about.
when I pointed the laser at the front cats(inlet I’m assuming is what it’s called?) that are attached at the manifold I’m getting around 400-500+ degrees F depending on where I point it but that’s the rough reading temp. Then when I point the laser at the rear cat I’m getting a reading of around 250 fahrenheight ?
Is this a indication that the catalytic converter needs replacing or ?
