I've had my truck for about a month now and so far I've done the egr and dpf delete. Ive recently removed the CCV filter and rerouted the vent line from the pre turbo inlet. I capped off the inlet at the turbo and I also capped off the intake line off the valve cover. I removed the CCV filter off the top of the motor and cut it apart, being careful not to damage the top half that held the filter, I gutted and cleaned it out. No more potential vent restriction to the crank case should the filter plug and more importantly no more feeding the compressor side of the turbo with oil from the crank case.Pretty straight forward mod, took about 1& 1/2 hours, the bulk of that digging out the filter and the glue that holds the filter media in the cover and cleaning it up.
