2005 Wrangler Unlimited. Started to run rough so pulled over then engine died. I smelled a plastic burn but it was 7pm and no light and got it towed home. Had battery lights radio etc. but engine would not even crank. Next morning popped hood and the center coil was split and white plastic (now hard) oozed out. I never changed the ignition coil before so purchased one and new spark plugs changed everything back together and no crank at all. When I put the key in the start position the gauges didnt even move. The battery shows 12volts but never had it checked yet. Any ideas on why I am getting no crank and no moving on my dash gauges?
