Chirping sound from front right wheel
Smokngun
Nashville
I hear a chirping sound from my front right wheel. Could that be wheel bearings? Any suggestion on what brand to get?
Sometimes, if you look close at the U joint, you’ll see red oxide powder, which is indicative of rust on the needle bearings. Grease not only lubricates, but keeps water out. Think of it as heavy oil.
Are you sure it is the right front? It can be hard to tell where these noises come from. The normal chirp generator is the centering ball in the front drive shaft double-cardan joint. If it is that you want to get it fixed real fast.
usually the culprit whenever I hear a chirp, but it’s always the rear for me
Reactions: Smokngun
I had a random chirp at one point. Everything looked good and felt good. I decided to change the u-joint out just in case on the side it was coming from. It was dried out and the chirp went away with the new u-joint.
OK for a newbie like me can someone help me with the various u-joints. I will change the axle shafts u joints with Spicer 5-760x. What brand for the other u joints?
Timken for wheel bearings not sure on the bushings, probably crown or another similar one unless you can find mopar.
Reactions: Smokngun
Lift the front wheel on the side you think is chirping. With the steering wheel turned somewhat to the side so the U-joint is not straight, rotate the front wheel. If you get 2 chirps per revolution it is the U-joint. If you get 12 to 16 chirps per revolution it is the centering ball.
