Hopper TJ Addict Supporting Member Joined Dec 28, 2018 Messages 1,530 Location Georgia Nov 4, 2020 #1 Noticed today when front is jacked up and Jeep in in neutral there is a clicking noise in the front differential when I spin the tire. Normal??
C Cross-Threaded-06TJ Guest Nov 4, 2020 #2 Sounds like it has a locker installed. If you didn't put it in there somebody did. Pull the cover off and find out.
Lou Don’t drink the koolaid Supporting Member Joined Jun 16, 2016 Messages 2,864 Location Long Beach Nov 4, 2020 #3 Worn spider gears make a clicking noise
OP Hopper TJ Addict Supporting Member Joined Dec 28, 2018 Messages 1,530 Location Georgia Nov 4, 2020 #4 Cross-Threaded-06TJ said: Sounds like it has a locker installed. If you didn't put it in there somebody did. Pull the cover off and find out. Click to expand... Thank you,Yes there is a locker in th ed front. So it clicks even in neutral and not engaged? This Jeep is making me a jeepacondriak Reactions: Cross-Threaded-06TJ
C Cross-Threaded-06TJ Guest Nov 4, 2020 #5 Hopper said: Thank you,Yes there is a locker in th ed front. So it clicks even in neutral and not engaged? This Jeep is making me a jeepacondriak Click to expand... Yes sir.
Rubicon88 TJ Addict Joined Sep 24, 2020 Messages 2,400 Location Western PA....Altoona area to be exact. Nov 4, 2020 #6 Hopper said: Thank you,Yes there is a locker in th ed front. So it clicks even in neutral and not engaged? This Jeep is making me a jeepacondriak Click to expand... Indeed unless you have lockout hubs to disengage the front axles. Reactions: Hopper
