My thinking is that CO2 might be more reliable and less trouble than the currently problematic air pumps I have, and it would also function for airing up. But then again, that is why I’m asking.Not sure why you'd want to do that. Many use CO2 because it's faster for airing up tires and using air tools. I just don't see a need to use a CO2 tank for lockers. A tiny inexpensive air compressor is going last a long time and work well.
I carry a CO2 tank and use it most of the time. That is, until it's empty. Then I use my air compressor. With your idea, when the tank goes empty, now you don't have functioning lockers.
I’m not a fan of ARB pumps, I will be running ARB’s with the small Powertank kit for my YJ build. They have everything you need if you want to go the same route I am.Has anybody ever done away with air pump actuators for their lockers, and replaced with regulated CO2 pressure?
If you have a Rubicon, you'd just have to make sure you got a quality regulator that could reliably reduce that high CO2 pressure to the 5 psi required by the lockers. Much more than 5 psi and you'd have blown bladders inside the locker actuators. It would require nothing more than a T-fitting to the regulator to drive the lockers.My thinking is that CO2 might be more reliable and less trouble than the currently problematic air pumps I have, and it would also function for airing up. But then again, that is why I’m asking.
Jerry’s got a great point if you have a Rubicon.If you have a Rubicon, you'd just have to make sure you got a quality regulator that could reliably reduce that high CO2 pressure to the 5 psi required by the lockers. Much more than 5 psi and you'd have blown bladders inside the locker actuators. It would require nothing more than a T-fitting to the regulator to drive the lockers.
I agree to an extent. It seems expensive but with most things, you get what you pay for.Also Powertank parts are pretty overpriced, you can piece something together locally or through Amazon at a decent discount.
Can you show me the parts to piece together that are are of the same quality and can perform just as good if not better than the PowerTank stuff? If I can save a buck and have the same performance or better, that would be great.
