Front 158lbs/in, 18.5" free
Rear 200lbs/in, 13.75" free
jjvw got the BDS rates correct. Since the JKS are 8lbs lighter in front and 10 lighter in the rear, I would expect the JKS to ride very similar to the BDS. Maybe a little softer and smoother. They say the dual rate makes it softer.
Dual (combined) rates is completely different than linear. I don't understand it very well.
Your thinking about this formula for combined rates aren't you?
CR = (R1 * R2) / (R1 + R2)
I understand that is the formula used to find the combined rate in coilovers and systems with 2 separate springs. But I don't think that a single 'dual rate' spring is going to act the same way as 2 single springs that are stacked on top of each other.
My knowledge is limited on this as well, but here is my reasoning. In a system with with 2 different springs, like a coilover, each spring is independant of the other. So each spring has to carry the load independantly. The top spring is not aware of the bottom spring and viseversa. So if you have a 50lbs spring and a 100 lb spring they will each compress independant of each other. However, with a dual rate spring, the spring is all one unit so the compression on the lighter rate is also transfered down to the lower rate.
Think of it this way. If I have a linear rate spring rated at 100lbs, then I cut it in half, is it the same as it was before. The formula says that I now have a combined rate of 50lbs (10,0000/200=50). But if I weld that spring back together again I will now have the same 100lbs spring. Since a dual rate spring is all one spring, I don't think that formula is accurate. I think that formula only works when the springs are acting independently.
I'm inclined to think that in a dual rate spring you will feel the softer rate until it is in full coil bind. Then you will feel the firmer rate. But that is just how I am thinking through it, I don't have any actual experience.
Sorry to take this so far offtrack, I thought we were in the JKS Jspec thread. So now back to control arm bushings.
