Been reading (searching) a lot of threads on replacing the control arms. I'm about to on my 98 TJ using the Core Tier 2's. Working on a slightly angled driveway at 5 degrees and after just installing a Teraflex 2" lift myself, i'm wondering if working on a slight angle like that is making it more difficult to remove/replace the control arms? Seems they're under a slight load and most of the bolts are hard to remove. Is that normal even on level ground?
Also, working at that slight angle.. would it make them harder to put in and/or align things afterwards? I read the rear uppers are the most critical, at least with the lift I have and rear lowers along with front upper/lower should be set at stock length.
Working on the driveway is the most ideal for me so I'd like to do as much as safely/correctly possible there but if I have to finish it up on level ground and adjust things I definitely will.
