Hey y’all,
Being doing some work on my 1998 wrangler. 74,000 miles. Went to pickup a warn winch today and after about a 25 minute drive in the AZ heat, I pulled over and could hear some hissing and smelled coolant. Had two hoses leaking. I have a reader plugged in and has been driving at 210 and gets up to 225-230 on highway speeds.
I top it off, pick up the winch, and head back home, keeping on eye on my temp. Highway stayed at 230 cruising and never above. Back to 210-215 on streets, running fine. Got home and went to check on it and the coolant wasn’t hissing this time around but the coolant was bubbling in the reservoir. (Panic as in my head this always meant head gasket). Dipstick is clean - ran fine and never got above 230 at its peak - highway driving in AZ above 100 degrees out. Radiator is rusty when I take the cap off.
Dropping off to the mechanic here next week, gonna tow it there to be safe - but plan on doing a full overhaul of the cooling system. Radiator, waterpump, thermostat, hoses, etc. it’s a 98 and I believe they are all original so figured I better just get it done.
Nervous it could be a blown head gasket - but also see that air in the system can cause the bubbling in the reservoir so trying not to panic to much.
Curious what you all think.
