Correcting speedo with Digital Dakota?
I can't speak for that specific model but the link below is pretty highly accredited in the Jeeper community. In the coming months I plan to switch from gear driven speedo to this one:
http://www.bluemonkeymotorsports.com/products_ht.html
One benefit is it appears really easy to wire in with the video. It may be of some use to you.
Edit: Dang I need to read closer, re-reading over your post it sounds like you have already purchased one. In the event of that, Stu has a writeup that may or may not help. It is a different product but nevertheless:
http://www.stu-offroad.com/engine/speedohealer/speedohealer-1.htm
Reactions: PriddyBoy
+1 on the Blue Monkey product. It plugs into the existing harness going into the transfer case. Really simple to set up. If you haven't already started stripping wires for the Digital Dakota one, you might want to consider changing directions. If you're set on the Dakota, google this: Dakota Digital site:rubiconownersforum.com. Looks like a few posts at RubiconOwnersForum.com on it.
+1, I still sift through the other forums from time to time but the TJ community here is better, less trolling.
Sent from my iPhone using Tapatalk Pro
I put one of these on when I installed my sssye. Have you figured out the wiring and just need help wth programming? If so I can go look at mine and tell you where my switches are set.
