Wow. Thanks. So that's the hub cap that's on my current 16 inch rims with the 33 inch tire. they happen to fit the new rims I'm putting on as they didn't have their hub caps. Thanks again!!!Yes, that number ending in AA is the part number. It shows that it came from an "Alcoa" wheel, which has the following specs:
* 15x8 forged aluminum
* 5 on 4.5" bolt pattern
* Backspacing = 5.5"
* Offset = +25 mm
* Standard wheel with 2004 Rocky Mountain Edition and 2006 65th Anniversary Edition.
So now that got me wondering because the rim that the hub was with is not aluminum. Here are numbers from the rim. Does this identify the rim by chance? Thanks for the helpYes, that number ending in AA is the part number. It shows that it came from an "Alcoa" wheel, which has the following specs:
* Offset = +25 mm
* Standard wheel with 2004 Rocky Mountain Edition and 2006 65thAnniversary Edition.
The center cap is from an aluminum jeep wheel and these are steelAll I see on that wheel is the size, 16x7, and manufactured date, 10/19/2012. Can ya post a front pic?
I figured they were. My boyfriend just remembered where the center caps were for the rims I'm using with the new tires im getting in the next couple days. He was using them to hold his nuts and bolts . Lol. They are American racing wheels but impossible to find out exact specs on them. The cap had numbers but they don't identify like the jeep ones do. I but at least they are a bit higher quality it sounds. Thanks for your helpThose are shitty (sorry, it's true though) aftermarket steel wheels. Someone re-used the stock center cap from the factory "Alcoa" wheels.
FYI, steel wheels are garbage in my opinion. Get an alloy wheel if you upgrade.
True. Years ago seemed like we all ran AR 767's. Budgets being what they are, there was no way I was going to run a 300 dollar wheel and tear it up on rocks.Steel has it's place. Just because you don't like them, Chris, doesn't mean they are shitty.
Biggest advantage to steel, imho, is that it can get pretty severely bent, and still hold a bead. Alloy tends to crack and leak.
