You'll have some killer droop with those shocks. Just don't go chasing after your springs when they fall out, lol!
Uptravel is appreciated equally. Springs can’t fall out if the bumpstop extentions retain them.You'll have some killer droop with those shocks. Just don't go chasing after your springs when they fall out, lol!
Ok so thinking this out, I truly believe getting 4" Currie springs will not do squat to help me here. My 3-3.5" of required bump stop is shock limiting so I need to question the shock:We are. So, make your fixes to the rear and live with the travel you have, and wait to bump up to 4" springs and 35's.
Or, outboard the rears, and do Blaine's mod to the front spring perches to get some more shock real estate. You many need to sell a kidney for this one.
I appreciate you clearing things up, that makes it much easier to understand.It's too long. Fully compressed, the shock is limiting your travel. Another way tho think of it, the body of the shock is too long...
I'd almost think about selling those, and getting something else, now that you can measure you actual setup.
I honestly wouldn’t be able to tell you.Focusing on the front, I have a question. How much suspension travel do you think you had when it was in stock trim? That would be with no added bump stops and jounce bumper removed.
Misunderstood the question the first time, yes.Wouldn't it be 3" less than what it is now, sans the added bumpstop pucks?
The rear shock relocators will be coming off. School me on what is wrong with the hockey puck bumpstop setup?I think this kits been designed for a 33" tyre with no body lift or a 35" tyre with a 1.25" body lift.
Personally, I'd be doing the Blaine mod to the rear shock mount and then looking at a better bump stop arrangement than the current hockey puck one then leaving it at that.
As you are looking at 35's I'd be fitting them up first and re-visiting the issues then.
Mevotech, they have been fully pressed in, twice. They don’t stay in, so researching alternatives.
Also on my to-do list.The ball joint is fine, it's the holes that have been widened by your previous set of ball joints which were knurled as Blaine mentioned. You either have to dimple those ball joints or get another set of knurled joints like Moog.
I went through this before, going from knurled AlloyUSA to the factory Spicer, and had to dimple the housing so it could be pressed in securely.
https://wranglertjforum.com/threads/ball-joint-fix.2389/
Sounds good. I appreciate the help guys.Fix the rear shock dealio, knock the rear bumpstops to 3" and run it. Your travel is same as stock. That ain't the end of the world.
