Hi all,
I am looking at purchasing a 2005 TJ, has the 4.0 I6, I dont know the trim level. My question is, the guy selling it said that it originally had the 6 speed manual transmission in it, and for some reason he had a shop swap in a 5 speed manual.
As of right this moment I dont know which 5 speed he swapped in.
The issue is the jeep is off timing due to the crank position sensor being in the wrong location on the bell housing. (He said the shop didn't know about the crank position sensor needing to be in a specific location)
Does anyone know how easy this is to fix? Or steps I should take to help troubleshoot this or even get around it?
I know of the ax15 conversion bell housing and I have read that if you pull a newer tranny to place into a older chassis to make sure its respective flywheel goes with it and stuff so I have a general understanding of that. But if this was the NV3550 what are my options?
I have called around to about 10 off road 4x4 shops in my area and I havent gotten anywhere. Any help would be much appreciated and ill update as I get more information!
Thanks
Thanks
