Crossing streams
Nooo! Yeah, I plan to be second. And/or walk it first… Man, that looks like a bad day!!!
I drove it home... but spent the next three weeks tearing it apart to clean all the sand and gravel out of EVERYWHERE! lol...
Since then I've driven it from Memphis area to Moab x2, Arizona, Kansas, TX... and back and forth to SMORR and Hotsprings.
... and yes... always be second or walk it...
... and we wheel alot down in the Ozark Adventure Trails... lot's of river / creek crossings... I got way too confident... then got caught!
The 32rh stock vent location is in the bell housing. Relocating it is a chore. I would do some research on the topic. I have read that forward momentum keeps the water out, but that is just what I read. If you get stuck in water as high as the vent, it can be costly.
It's involved. Drop the transmission (obv). Tighten the kickdown band adjust to hold the direct drum in place. Pull the pump. You have to plug the hole on the pump, and then drill & tap a hole in the top of the case. A greased paper towel laid across the geartrain will catch the aluminum shavings as you do it. Then put the pump back in & perform the band adjustment.
Although if you get to the point of removing the pump, it is a trivial amount of effort to replace your frictions (and steels). And you're close to having a fully rebuilt transmission.
I think I have a how-to writeup for the vent relocate.
Reactions: Matt H and tworley
Forgive me if this has been stated, but if what you’re doing has to happen I would have extra fluids and make sure you have the correct tools to put them in and to drain any water.
You can watch the expedition of the Americas to get an idea of the level of preparation and extreme things that can happen trying to traverse the jungle.
Keep in mind those particular vehicles were mechanically and electronically far simpler.
i’m not a fan of getting into water really deep, but if you have to do it, try to think comprehensively about everything that could happen.
I've always heard that in water deep enough to get into your clutch (manual trans), you do not want to press in the clutch pedal.
Sometimes there are big enough rocks/roots in the water you can get hung up and kill the motor, so I pulled the fuse that allows me to start it in gear.
I'd be curious what the experts in here say about that and how the mechanics of getting water between the clutch and the flywheel affects it.
@lBasket what did you do for this crossing? 😅
I'll be doing the Rubicon, Fordyce, and Barret lake this summer... there is a river crossing on Fordyce that can be pretty spicy...
Just a random pic I snagged off the internet...
... I might even be more nervous about that than Winch Hill 3... lol
Thanks, I’m talking about shallow streams maybe 12”-15” deep max. I just wanted to check my vent hoses and make sure everything is as it should be. Perhaps re-route some as has been suggested. But yes, I always have fluids, tools etc with me.
Howdy, I'd like to add in my 2-cents for what it's worth. I'm a big proponent of walking water crossings before driving into them. I know that this is not always practical or sometimes possible. BUT even on a familiar or frequently used crossing there can be significant changes if there has been a big rain, snow melt. etc. or a long time has passed since you last used it. Plus there is always the inexperienced or idiotic driver that has torn hell out of the crossing where you can't really see it. I'd like to relate a personal experience. Once upon a time, In Australia, in the Glass House Mountains, we were doing some exploring. The area at the time was pretty undeveloped and very beautiful. It also has water crossings. Lots of water crossings. Knowing that they could sometimes be traps, we were pretty diligent about walking these crossings and every one of them was crystal clear water less than about 14 inches deep with very firm bottoms. Until the first one we didn't walk. Gloop, right up to the frame. We spent the rest of the day trying to self-rescue without any progress at all. Of course, we had no winch. Ended up spending the night (hot, rainy, and mosquito filled) and hiking out lthe next morning to get help. So... 2 amused park Rangers and one irritated Farmer with his tractor later (Bless him)... we finally got going again. Take a minute and survey the situation. It'll pay off. Have Fun!
It's not the water at all, it's all the grit, sand, and other contaminants suspended in the water that get in there (via the water...) and score the surfaces.
And no matter how much you clean, unless you can put it on a lift and pressure wash from the bottom side it will take months to get all that crap out!!!!!!!!
Reactions: Rickstar321
