Grease won't come out. The best way to grease a JJ is to disassemble it.so I’m not the only one. Can you run it with the Zerk fitting removed or will grease come out?
Should plug the hole when you remove the zerk.
Mine had interference too, I plugged the hole and greased it by disassembling. I’ve never gotten any of my 18 JJs to take grease through a zerk.
There’s flush plugs you can use or use a flush greasable type (needle zerk).what did you plug it with?
X2, 1/8 NPT size.
Yes. But the more accessible location is also the same place where it would get wiped away on a rock.Just wondering if it can be plugged and drilled and tapped in a more accessible zerk location..
Grease goes in, not outDo you guys not call those grease nipples?
or is that just too explicit?
Otherwise known as a check valve.Grease goes in, not out
What a great way to say thisI tickled it
