I’m going over different options for my SE Dana 35 and I’m am leaning towards the Truetrac. My question is if I need to replace the ring and pinion at the same time if I’m going to keep the factory 4.10 gearing. The Jeep has just over 70,000 miles and there are no issues with the original equipment. Is it advisable to install a Truetrac with new carrier bearings, upgraded 1541H 27 spline axles (Dutchman), and new wheel bearings while reusing the ring gear and leaving the pinion untouched? I would obviously be checking the backlash before removing and probably check the axle end play as well and making sure that the new carrier functions the same and adjust shims if necessary. Does this sound ok? Any advice?
