First, I am in the middle of learning here, learned a lesson the other day and a Rubicon got away from me.
One of the things I did learn was the Dana 44 Axle was important to have;
I am thinking that the TJ Rubicon came with Dana 44 which is 4:10 ratio and comes with air lockers, (the Rubicon I was looking at had On Board Comperessor) and Rear disk brakes.
If I had a TJ, what ever year, would say a '04 TJ Rubicon rear axle (as described above) bolt up. Is there a break in the years? for example 97 to 03 and 03 to 06, would this axle be interchangeable.
And to go a step further, would the front axle have to come from Rubicon also? Would it have to be 4:10 ratio to match the rear axle?
Or is it just better to buy lockers for the axle you have and the gears you need depending on what size tires you are running?
Last if you found an axle what would be a good price, as in fair price, for complete rubicon rear axle ready to bolt in?
