As the title suggests, I am having an issue with the dash "brake" light staying on. Other than the parking brake switch, are there any other brake-related systems that would cause this? Also, I checked the wire going to the parking brake switch with my trusty circuit tester and it is hot when the key is on. Is that normal? I have tried to find a replacement switch just to see if that is the issue, but it seems that part is not available for my 2000 TJ.
Can I just ground the wire going to the parking brake switch to see if it is that switch?
Thanks!
Thanks!
