Sasquatchewan
Thanks Phil I ran my Serial number through Jeep online, to check for recalls & it said no outstanding recalls or issues.
I don't want to hijack this thread, but I'd be curious for some explanation. What other mods do you feel need to be done to a 4-cylinder and not the 6-cylinder? And, what mods do you feel were designed for the 6? I've done a lot of significant mods to my 4-cylinder TJ that were neutral of engine specification/size. I really can't think of anything I've done where that would've made a difference...Be aware that there are more mods that need to be done to a 4 banger jeep than a six. Also almost all mods are set up for the six, so your results with the four will vary. This is especially true for things like lift kits. The four is sensitive to weight, if you plan on adding a bunch of stuff or carry a lot of gear it will show. Like I said, I love my four and actively sought a good one out, but my usage is a corner case not typical.
Thanks I am going to order the OPDA from Quadratac since its so Cheap anyway, I'll pull out the old one to check it , but the Crown should provide a peace of mind.I agree that 12-12,500 would be great. I paid 12k for my '06 unlimited with 110,000 miles that was also very clean under and all around with decent aftermarket rims and worn 31's. I was hoping for a Rubicon Unlimited but at the time they were all going for 20K+
Be sure to ask the seller if he changed or inspected the OPDA. You can have issues without having the "laughing monkey" sound.
Sasquatchhewan-I also ran my VIN# thru the Mopar site and it came up with no recalls. However I would guess my time was getting short with my OPDA- maybe 15,000 miles?. The Crown unit was only $109 and is a much better design so I was glad I changed it. You really will not know for sure unless you pull it but be careful to mark the timing so you will not have issues.
Oh and be sure to check the exhaust manifolds. They tend to crack on the 4.0s. And the 05/06. ( may be others too) the precats are prone to fail flow down stream and plug the main cats. Don't ask me how I know this---it still pisses me off.
If performance and fuel/mileage has not suffered I would not suspect cats.I'm throwing P0421. I used a spark plug fouler to "modify" the O2 sensor that was throwing the code and it went away.
With that said, do you think it's my O2 sensor or the cats? The previous owner had replaced the O2 sensors with some aftermarket ones (not NTK/Mopar) and I've read that anything other NTK/Mopar is likely to throw codes.
I have no performance suffrage so I'm not sure if it's the cats.
I had a neighbor that had a Chevy truck O2 sensor went bad , so he replaced it & the truck looked at the old one & thought it was bad because the new one was so much better. It took a while to catch this.
Well it was a Chevy, but I would always replace both or however many it came with.
