@AndyG has the forms for that but I have to warn you, we are backlogged with angry bird requests so it could take some time.that shit you sprayed on the flares and other bits should be grounds for revoking Jeep ownership.
It is the goober version of the heat gun bullshit.
That is a form 1062 TJORF (TJ Ownership Revocation Form).@AndyG has the forms for that but I have to warn you, we are backlogged with angry bird requests so it could take some time.
Take them offI may incur the wrath of Khan here but I'll risk it. I'm new to the forum and Wranglers or Jeeps that have something other than metal on them. I recently asked this question as well but refrained from asking if those who have done this preferred to remove the flairs for painting or masked them. Looking in the wheel wells it did seem too big a job to remove them. Masking can leave edges that look like you did not remove them. Advice???
BTW, I look for previous posts on subject matter before posting but in many cases don't put the correct info in the request to get the post(s), only to be referred to them after I ask the question. So it's not always just taking the easy street to get answers. Okay...fire away, I can take it.
If you like the gray look, there’s a SEM Color Coat for that!One for and one against. I suppose it's how good you are with the tape and the tape you use. A friend of mine used the three step process you can get from O'Reillys and taped his to restore the original black look. It's been holding up for a year and he did a good job taping but I can tell it's beginning to fade a little. As I mentioned in a previous post I kinda like the gray look against the Patriot Blue paint so I'm going to try paint first. If I don't like it then go back to the SEM produce. All my taste is in my mouth so the wife might chastise my choice. After all, she chose me so she must have good taste. We shall see and maybe I can post a picture after the job is done.
Hard to tell from a color card or plastic cap, but there should be some good choices here:Okay. The critics have me reaching for the wrenches instead of the masking tape. Alas, it's raining right now and this too shall have to wait. Appreciate all the replies and I will look at that SEM Gray
Hello, in reference to the monstaliner color matched dark khaki. How and where did you get the math done? I’m looking to monserline a set of flat hurricane fenders in dark khaki to match my oem rubihara flares. Thanks for info!! [email protected]I’ve done a set of flares with sem ultra matte black and I have done a set with monstaliner color matched to the dark khaki color found on some flares. My advice on prep is to wet scrub the hell out of the flares with scotchbrite, simple green, and water. After they have been rinsed and dried, shoot a light coat of bulldog adhesion promoter, skip the primer, and then apply your paint of choice. Also don’t use acetone or any kind of solvent. Products like those don’t play nice with plastic and paint adhesion will be poor.
I didn’t follow a paint code I just did it by eyeball. Monstaliner has quite a few tints you can choose from and I requested several samples and then bought a few to mix and match. Use the tints “dirtbag” and “charcoal.” I used the entire contents of the dirtbag tint and then added charcoal tint (it didn’t take much) until it almost perfectly matched the color of my hardtop in the sunlight (don’t use ambient light).Hello, in reference to the monstaliner color matched dark khaki. How and where did you get the math done? I’m looking to monserline a set of flat hurricane fenders in dark khaki to match my oem rubihara flares. Thanks for info!! [email protected]
