Does my 2003 ignition key have a chip in it, or is just a reg'lar ol' key I can get duplicated at the hardware store?
No chipDoes my 2003 ignition key have a chip in it, or is just a reg'lar ol' key I can get duplicated at the hardware store?
According to my search that gray one is chippedI was given 2 keys by the PO of my 02.... one grey, one black. Haven't even looked yet to see if their chipped.
Interesting. So are there any consequences to using an unchipped key on the Jeep?According to my search that gray one is chipped
yeah it won't stay running.Interesting. So are there any consequences to using an unchipped key on the Jeep?
The SKIM is plugged into a harness connector near the steering column and mounted under the upper cover of the steering column near the MFS. The grey keys need to be programmed at the dealer UNLESS you have a friend that has the factory access controller.
My local hardware store copies those keys for $40. The newer type that my '08 GC has they can't do, it doesn't even have a key at all, just a fob.
The gray oval key with the chip is the SKIM key. It started in 98 as an option. All TJ PCM's have the SKIM function built into them. After that it takes a module and programming of it to the PCM and the keys to enable it.
Nothing says "Jeep" like a key that has to have a module and be programmed by a dealer for it to work.
I sure am glad my 1998 model has a simple $10 key.
