PattonD Member Supporting Member Joined Jun 11, 2020 Messages 89 Location NTX Aug 2, 2021 #1 Does the blower motor harness resister have both plug ends? Looks like this melted a bit with the switch
CharlesHS TJ Expert Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 5,602 Location Jacksonville FL, Quezon Philippines Aug 2, 2021 #2 When you purchase the replacement resistor you only get the resistor; IF you need to replace the harness with connectors you can purchase them on Amazon.
OP PattonD Member Supporting Member Joined Jun 11, 2020 Messages 89 Location NTX Aug 2, 2021 #3 The resistor wires are working fine, it is the high that bypasses the resistor that seems to be the problem and think I need to switch end plug.
CharlesHS TJ Expert Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 5,602 Location Jacksonville FL, Quezon Philippines Aug 2, 2021 #4 You could contact one of the members that is parting out Jeeps in the TJ Classifieds; they may have what you need... Reactions: PattonD
