So I unscrewed the nuts on the doors and I can’t lift the damn doors off even with my wife and I pulling up!
Any recommendations?
Apply penetrating oil. Work the doors back and forth to let the oil penetrate down. Then apply more. Start working the door back and forth again while lifting. As soon as you have a little gap, apply more oil. Lubrication and working pressure up should solve the issue.So I unscrewed the nuts on the doors and I can’t lift the damn doors off even with my wife and I pulling up!
Sounds good will wd40 work the same? Save me a trip to the storeApply penetrating oil. Work the doors back and forth to let the oil penetrate down. Then apply more. Start working the door back and forth again while lifting. As soon as you have a little gap, apply more oil. Lubrication and working pressure up should solve the issue.
It should but overall WD40 is a pretty poor penetrating oil. My 04 doors had never been off and in 2016 it took two or three days of oil, exercise, repeat until they came loose.Sounds good will wd40 work the same? Save me a trip to the store
WD40 worked for me, I had the same problem the first time I took my doors off (i guess it was the first time in 18 years)Sounds good will wd40 work the same? Save me a trip to the store
