New member here... Trying to figure out how to resolve some driveline vibes on my TJ. It came with a lift, which appears to be the 4in RC lift kit. Has the TC drop from the kit, appears to also have the lower control arm from the kit, and also has a body lift. No MML. When I get it up to highway speeds, it's a smooth ride when coasting but the vibrations hit on acceleration, especially in lower gears.
I tried to take some measurements of the drive train angles using my iphone.
Driveshaft: 17*
TC output shaft: 14*
Differential cover: -8*
Don't know how accurate it is to use the rear diff cover, but that's what I've got so far. Attached photo was taken with phone sitting flat on the ground.
I've got u-joints in the mail, along with pinion seal. Planning to do that and refill the fluid.
How do these angles seem? I'm decently mechanically inclined and am trying to get this driving decently. I don't mind going lower with a TC drop temporarily to resolve this issue, but I'm trying to hold off on a SYE/CV. Would a lower drop or a MML help sort this out?
Greatly appreciate any feedback, thanks in advance!
Driveshaft: 17*
