Roger that @JMT , I remember looking at your mml and fan shroud.MML is the best solution if you're not wanting to lose clearance. Brown Dog or MORE are good choices. I have Brown Dog ($115). If you only do the MML, you'll have to raise the fan shroud 1". If you do a 1" BL too, you won't have to do that. Actually, both mods would be good for your setup, allowing more room for bigger tires (which you are looking at, you could do the 32x11.5's) and getting more clearance at your oil pan as well as solving your driveline vibes (Performance Accessories and Savvy are good).
But, if you want to know if the driveline is causing the vibes, do a simple TCase drop just as a check, should cost sub $10
And.btw you keep suggesting 32" shoes, I may have to check out 32s. Have not done that and thanks for your input
Decisions, decisions. Jeeps r fun !
