If you had a local shop lengthen a driveshaft and made it clear that it needed to be well balanced due to the speed it ran, and after installing it you had vibrations starting at 65 that intensify at least through 75, would you even mess around with the shop or would you just send it to Tom wood's (the original builder) and have them do their magic?
Background is I had 10" added to my TW shaft to use it on my LJ. Got the LJ above 50 for the first time yesterday and have a pulsing vibration from the rear end. It's definitely not at tire balance speed, and it feels different (more audible but less felt) than when I've had operating angle issues. It doesn't change based on accel/decel/neutral or disengaged clutch, and there is no front driveshaft installed. 6 speed with 4.88 gears, and for the time being 32" tires which means at 75mph the engine is around 3400rpm and the driveshaft should be around 4k. When I get to 35s it should help some but if it's going on at 65 now it'll still start before 75 with the bigger tires.
